parameters in xml file for custom thread
lu_zhengYAWZ6
Observer Observer
lu_zhengYAWZ6
Observer
Observer
I'm trying to create my own xml file to make a custom thread M32*0.75. I used a few thread calculators but with the tolerance (6g, 6H, 4g6g), they give me a range (min and max) for major/pitch/minor diameters, rather than one definitive number as in Fusion360. And the number from Fusion is not always the average of the min and max. Can someone help explain how Fusion360 determines those specific numbers? Below is one example with numbers from thread calculator and Fusion360 for M30*0.75 thread
MRWakefield
I've done quite a bit of work with Fusion thread files and i can confirm that the values are as far as I've experienced the mean of the max and min values. Some calculators and reference tables give different values so that might be where your observed differences come from. At the end of the day I wouldn't worry if there's a few microns discrepancy as the sizes aren't really used in any manufacturing process except for 3D printing. Obviously a few microns here or there when 3D printing isn't an issue.
I've developed a Windows application for working with Fusion threads which you might find helpful. You'll find a link in my signature to a forum thread explaining the application with a link to download it. There's a metric and UN thread calculator included. I can't guarantee all calculations are micron perfect but I believe it's fit for the intended purpose.
Hope this helps.
If this answers your question please mark the thread as solved as it can help others find solutions in the future.
Marcus Wakefield
____________________________________________________________________________________
I've created a Windows application (and now Mac as well) for creating custom thread files for Fusion. You can find out about it here. Hope you find it useful.
If you need to know how to offset threads for 3D printing then I've created a guide here which you might find useful.
If you would like to send me a tip for any help I've provided or for any of my software applications you've found useful, you can do this via my Ko-Fi page here.
lu_zhengYAWZ6
Observer
Observer
Thank you so much!
MRWakefield
You're welcome. If you need anything else or have any problems just shout.
Marcus Wakefield
