Parameter text dropdown menu unreadable
stahleash
stahleash
In the newest version of fusion, text becomes unreadable in the parameter dropdown menu, when created during sketching.
If created through the parameter window, text is unaffected.
When created during sketching, it puts a sketch icon in front of the text, probably causing an alignment issue.Top glitched text, bottom normalTop glitched text, bottom normal
Already tried changing High dpi scaling and switching to directx11 to opengl and auto select.
dsouzasujay
Hi @stahleash ,
Thank you for reporting this, and for the comparison screenshot, that helps.
From your description, it looks like the issue is specific to parameters created during sketching, where the dropdown text becomes unreadable, possibly due to the sketch icon affecting alignment. That is not expected behavior.
Since this seems workflow-specific, it would really help to look at the exact data.
Could you please share the design file where this issue occurs?
  • .f3z preferred (or .f3d if it is a single file)
If the file contains sensitive information, you can also send it directly instead of attaching it here.
Additionally, if possible:
  • A short screen recording showing the parameter being created during sketch and the dropdown issue
Once we have the dataset, we can try to reproduce it and take it forward.
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
stahleash
i created a new file to reproduce and record the bug. Its not file specific, it occurs in every project, doesn't matter if its a new project or a work in progress.
Here is the recording for reproducing the bug,
(view in My Videos)
Here is a recording, where i set the parameter in the parameter window alongside the parameter done in sketching.
(view in My Videos)
dsouzasujay
Hi @stahleash ,
Thank you for sharing the recording and additional details.
I was able to reproduce the issue on my end. We are now tracking this internally under FUS-246300 for further investigation by the development team.
Appreciate you taking the time to provide a clear repro, it really helped
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
Georgepbeer
Community Visitor
Community Visitor
hello, is there a fix for this, happening to me too?
brad9126
Happening to me as well. Fusion is up to date. This only started happening to me today. I last used Fusion 3-4 days ago and don't recall this happening then.
Is there a solution being worked on?
This makes it pretty much impossible to use parameters as no matter what parameter I type in, the result ends up being 1.
bhavani_sankuratri
Hi @stahleash
I wanted to check in and see if you still needed assistance, or if you found a solution to your question already? Let us know if you need further assistance by providing an update or if you have found a solution, please share it with the community so other members who may have the same question could learn from your experience.
Bhavani Sankuratri | Community Manager
