parameter name being replaced by value - bug?
I found an annoying misfeature (bug - in other words).
If you create solid shapes that have more than 1 parameter (ie box, cylinder, torus and spring) and you use parameter names, those names do NOT populate the dialog, if they were used before the dialog box appears, which can happen if you don't click to complete the initial dimension input.
For example, creating a box - after setting the plane and location, use a parameter name for the width, tab to next dimension and enter a height parameter name. Press enter to accept - The dialog appears waiting for the last parameter (depth). Using the depth parameter name the name appears in the dialog box, but width and height are only populated with values and not the parameter name. See attached screencast as a demo.
This means that if I'm using parameters, I have to enter the parameter name twice for it to be incorporated - something I often forget to do, and it can cause problems if I have a model and change the parameter later on, particularly if I haven't realised a dimension is fixed instead of parametric.
Regards
Peter
Life long R&D Engineer (retired after 30+ years in Military Communications, Aerospace Robotics and Transport Automation).
