parameter adjusting Body not adjusting correctly
cmullaneNH3DR
cmullaneNH3DR
I set the parameters of the square on the sketch and when I adjust the parameters i the box does not size correctly using the center of the square. The parameter name is "lamellafeedpipewidth" that I'm trying to change from 13 to a lower value. Please see screen cast and file.
https://autode.sk/324AyTB
Phil.E
The sketch rectangle you are driving with that parameter is fixed at the outer corner. Try using a coincident constraint at the middle of the rectangle to get it to change width from the middle.
The red arrows show the direction of changeThe red arrows show the direction of changeUse the middle pointUse the middle point
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
