First, I've reviewed old forum threads related to this topic in case there were any obvious solutions there. Nothing seemed particularly relevant.
Setup:
- I'm running the Fusion 360 trial, just installed a few days ago.
- Hardware/OS: 2019 16" Macbook Pro w/ discrete GPU, 32G RAM, macOS 11.6.1.
With an empty Fusion 360 document open, it runs consistently at 100% aggregate CPU, load distributed largely evenly across all six cores. Worse, it tends to keep the system fans running all the time, from low- to mid- level by audible volume. If I have the temerity to actually do anything, e.g. making a few lines and boxes walking through a tutorial, the fans scream at near maximum. Other CPU intensive work doesn't, e.g. big compiling jobs, don't tend to spin up the fans like Fusion does at idle. I'm quite familiar with parametric CAD suites; no other suite I've used demonstrates anything like this kind of poor performance behavior. That includes a web-based competitor.
Any advice?
This is not acceptable performance. I'm seriously evaluating Fusion 360 for CAM and possibly migrating some/all CAD workflow over from another tool. But cranking up a high-end laptop's cooling system like this when barely using the software is ridiculous. What am I to expect when I start to push it? Will it just fall over? Will my work be blocked?
