OK Button in all dialog boxes not active unless you hide and unhide any object
- Mute
- Permalink
- Report
this has been an issue plaguing fusion since ages. it dissapears and reappears with incremental updates. it was fixed for a while but with the last update it's back. as the title explains in the modeling space the OK button in all dialog boxes of all operations are greyed out/inacive, when you hide and then unhide any object in the browser the OK button becomes active again.
THIS IS A MAJOR PAIN !!!!! Please fix this once and for all !!!
This has been reported many times already, including by me here: https://forums.autodesk.com/t5/fusion-support/ok-button-constantly-greyed-out-hiding-unhiding-any-el...
this bug even dates back to 2016 !!! https://forums.autodesk.com/t5/fusion-design-validate-document/ok-button-greyed-out-not-working/td-p...
AppleSilicon Macos 26.4
GENERAL DISCLAIMER: if there isn't a file attached to my posts then there is a reason for it. Whenever needed or whenever i can i will attach a file for troubleshooting. If no file is attached i will always try to explain as clearly as possible and if needed or helpfull provide illustrative screenshots. When i have an issue that can only be helped by attaching a file which i cannot share publicly i won't ask about it here.
