offsetting a rectangle or other shape
Looks like the offset command will work with a circle but not a center point rectangle? Am I wrong?
How about another shape made up of arcs that have all been connected? For example, say I had a file with a handle to a folding knife and I wanted to offset the liners with a different material overtop of it, but just smaller. Like this pic. Is that possible?
i-mXD4qrh-X2
HughesTooling
Have you got chain edge enabled? I have no problem offsetting a centre point rectangle.
Mark
Mark Hughes
Owner, Hughes Tooling
HughesTooling
Your second questions sounds like you're asking about offsetting surfaces. Offsetting surfaces can be tricky if you have any tight corners but should work if you have a good surface\surfaces with nice clean curvature.
Mark
Mark Hughes
Yeah I've tried it with both... I should have been more clear. I can offset the rectangle if it's not finalized and the dimensions are undefined, but if it's finalized (black) and I want to create a new sketch that is offset from the face of a previous sketch, it doesn't work for me.
HughesTooling
Still should be no problem. No sure why you have a problem with this.
Mark Hughes
Thanks Mike! Found out what I did wrong... I was trying to offset the rectangle while not editing the rectangle sketch, I was trying to do it from a new sketch. So my question is: if I wanted to make a new sketch with an offset rectangle from the original one, is there a way to do this?
HughesTooling
In preferences there are setting for auto project, personally I turn them off. I think what you saw was autoproject edges on reference. If you turn that setting off and Autoproject geometry on sketch plane then if you create a sketch on the face of a box, press P for project, select the face then OK out of the project command you should have a rectangle you can offset.
Mark
Mark Hughes
