No "Select Referencing Joints" option on linked parts
sylvainmartin73
sylvainmartin73
In Fusion 2.0.5350, If I add an existing part to a new design and do a join between the 2 parts, In my example, I created a bracket and added a endstop design to it, I perform a joint but if I right click on the endstop assembly, there is no "Select referencing joints" option. I'm pretty sure I used to be able to do this. See attached screenshot.
jeff_strater
it seems to work for me.  Are you sure that this component has referencing joints?
and, as always, if you can share your design we can take a look at it.
Jeff Strater
Engineering Director
sylvainmartin73
Here's my design example. I have a rigid joint between the 2 parts. If I select the endstop bracket I can see the "select referencing  joint" option but if I right click on the endstop2 component, there's no  option for it. Here's the file for it
https://a360.co/2DHXGJ7
