No objects on render window
diegoEQC2Q
Message 1 of 19
diegoEQC2Q
When I select the render window there are no objects. If I use the canvas render or the normal render the objects render as they should.
The app is updated to the latest version and it has been happening for 2-3 weeks in a Mac mini M2 Pro and a MacBook Air M4.
Thanks 😉
Replies (18)
Message 2 of 19
lauri_barnhart
Welcome to the community, @diegoEQC2Q.
Hope you are well. Would you be willing to provide some additional information such as your product version? Any additional information you can provide would be greatly appreciated.
Let us know how we did on Trustpilot.
Lauri | Community Manager
Message 3 of 19
diegoEQC2Q
Hi 🙂
Here is the info:
Fusion 2705.1.25 arm64 [Native]
Plano activo: Personal
macOS 27.0.1 (26A434) on Mac16,13
It happens with some projects, but with others the render works fine.
Thanks 🙂
Message 4 of 19
RajkumarIlanchelian
@diegoEQC2Q I this happening on all our designs? If you go to display settings and environment and change it does that help?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 5 of 19
diegoEQC2Q
It happens with some projects, but with others the render works fine. There is no setting I can change to make it visible, I have tried everything.
I attach a project with the issue.
Message 6 of 19
lauri_barnhart
Hi @RajkumarIlanchelian - tagging you to see if the information provided by diegoEQC2Q helps resolve his question.
Thanks for any input you can provide.
Message 7 of 19
RajkumarIlanchelian
@diegoEQC2Q I used the design that you attached and I am not seeing the same issue on my side. It's likely one of the setting either in preferences or somewhere that we are missing to identify. Do you have dark mode on? When you go into Preferences - General - Render what are your settings?
Autodesk Fusion
Join Fusion Insider
Message 8 of 19
RajkumarIlanchelian
@lance.carocci Any thoughts on what settings might cause this?
Autodesk Fusion
Join Fusion Insider
Message 9 of 19
lance.carocci
Since we can see the selection glow of objects in the render canvas, that suggests to me that it's less of a graphics issue and perhaps more related to the data model. I'll ask around!
Lance Carocci
Fusion QA for UI Framework/Cloud Workflows, and fervent cat enthusiast
Message 10 of 19
diegoEQC2Q
Well, you are not going to believe it. I found the issue...
I was changing the language to "English | English" so I could take some screenshots for you of the preferences page. Guess what, now works. So the issue is with the "Spanish | Español" language. Switching back to "Spanish" makes it invisible again.
Message 11 of 19
lauri_barnhart
Hello, @diegoEQC2Q.
Hope you are well. If I'm reading your reply correctly, your question has been resolved. Would you be willing to mark your reply as the 'Accept Solution' by clicking on the button on your reply?
Message 12 of 19
diegoEQC2Q
Hi there, it's not resolved. The issue happens when the "Spanish | Español" language is in use. That needs a fix.
Message 13 of 19
diegoEQC2Q
Hi there 🙂
any news on the fix?
Message 14 of 19
lance.carocci
Hi @diegoEQC2Q,
We are struggling to reproduce this issue on our end. Could you please attach diagnostic logs for the Spanish client session? Additionally, please try updating to the latest release, as it formally supports macOS 27.
Lance Carocci
Message 15 of 19
diegoEQC2Q
The app is updated to the latest release. It should be easy to replicate the issue as I have the same bug with two different devices as I said (M2 Pro and M4).
[Información de GPU]
Dispositivo GPU: Apple M4
Memoria RAM de GPU: 12124 MB
API del controlador GPU: Metal
[Parámetros de efectos gráficos]
Utilizar gráficos de alta resolución: Activar
Anti-aliasing: Desactivar
Oclusión ambiental: Desactivar
Sombra de objeto: Desactivar
Sombra en el suelo: Desactivar
Reflejo en el suelo: Desactivar
Estilo de visualización de selección: Simple
Efecto de transparencia: Mejor rendimiento
Message 16 of 19
lance.carocci
We are investigating an issue related to using Render while Section View Analysis is enabled. It will require a patch, but the exact release has not yet been established.
Lance Carocci
Message 17 of 19
diegoEQC2Q
Mmm... how do I know if that is my issue? How can I disable that?
Message 18 of 19
lance.carocci
The Analysis folder in the component browser contains any existing section views - expand this to see if any are enabled.
Lance Carocci
Message 19 of 19
diegoEQC2Q
Yeah, that was the issue. I hope it gets fixed soon 🙂
