No Content for Uploaded .f3d File
Don_S_Greer
Message 1 of 8
Don_S_Greer
A friend sent me a .f3d file, which I then uploaded into Fusion.
I see no thumbnail for the item, and when I open the file there appears to be no content.
Can anyone assist me is determining why I cannot access the file?
Replies (7)
Message 2 of 8
jhackney1972
Can you please attach the F3D file in question?  Also, you need to find out how your friend Exported the F3D file from Fusion before sending it to you.  Here is the proper process, see if they follow it.
If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it. You can also attach the resulting file to an email. If needed, ZIP a F3Z file.
John Hackney, Retired
Message 3 of 8
Don_S_Greer
File attached.
Message 4 of 8
g-andresen
@Don_S_Greer  schrieb:
File attached.
where?
günther
Message 5 of 8
Don_S_Greer
Attached.
Message 6 of 8
jeff_strater
yes, I can verify that that design is completely empty.  You need to go back to the person who sent you this file, because it seems they sent you the wrong file.  Nothing we can do on this end, I'm afraid
Jeff Strater
Engineering Director
Message 7 of 8
Don_S_Greer
Thanks Jeff.  Per chance, can you please educate me on the correct steps to export a file and send by email?  I can pass it along to my friend.  Thanks again.
Message 8 of 8
jhackney1972
You did not read message #2 where I explained the process.
