New update not loading - crash
PeterBelfanti
PeterBelfanti
The last update is not loading on my mac. because it will not load I cannot open newer file versions on it. where do I send the log file?
innovatenate
Autodesk Support
Autodesk Support
You can upload it here and we'll be happy to take a look. You can run the Help > Diagnostic Log file command to automatically collect all the relevant files for you.
Most of the time there is a permissions issue due to an unexpected exit or a rogue process running in the background. You may try restarting the computer to clear a possible permissions issue. An assured solution would be to perform a Clean Uninstall using the Fusion Cleaner tool in the below link and then installing fresh.
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/How...
If this is something happens regularly, you may need to configure anti-virus software on the computer for Fusion 360, the below link may help guide you to do that.
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/Con...
I hope this helps! Please let me know if you have any questions.
Nathan Chandler
Principal Specialist
