New Project Operation Failed
Message 1 of 19
I haven't used Fusion 360 in several months, but decided to run it today. My free trial expired, so I signed up again as an enthusiast again. Now when I try to create a new project, I get the error "Operation Failed" immediately. I uninstalled and installed a new version with the same result.
From the myhub web interface, when I can see my existing projects and when I try to create a new project, it fails and I get a popup box that says:
Project limit exceeded
You’ve exceeded the number of projects allowed in the A360.
Based on searching through the forums, this looks like it may be a bug on the backend side when a free trial expires? Can you please take a look?
Thank you,
Rich
Replies (18)
Message 2 of 19
saito.kh
Autodesk Support
Autodesk Support
Hi @Anonymous,
Thank you for posting and welcome to the Fusion community!
I am sorry to hear that is happening!  Just to check - it may be that the Start-Up/ Enthusiast entitlement just needs a bit of time to sync.  If you check the Help > About dialog, does it list the entitlement type?
If it does list correctly, can you please post the Diagnostic log files for Fusion in the system, by going to the help menu ([?] icon) on the right top corner of the Fusion window and selecting "Diagnostic Log Files in the menu?  It would be helpful to investigate the issue.  This web site guides how to collect the log files.
If you have any questions, please let me know.
Thanks.
Kanehiko SAITO
Product Support Specialist
Fusion Webinars | Tips and Best Practices | Troubleshooting
Message 3 of 19
It is working again. It appears to have been a sync issue. Even though I wasn't able to create a new project during the time it was 'desync'd', I could still create a new design within an existing project, so I proceeded to do that and it saved just fine. Now that I can create new projects, I'm good to go! Thank you.
Message 4 of 19
saito.kh
Autodesk Support
Autodesk Support
Hi @Anonymous,
Thank you for the update.  I am glad to hear you resolved the issue!
Enjoy Fusion,
Kanehiko SAITO
Message 5 of 19
1326Design
Community Visitor
Community Visitor
I'm having the same issue.  I haven't used Fusion in about 6 months.  My hobbyist license expired so today I dropped in and payed the $500 for an annual subscription.  All excited to jump back in and get started on a new project.  Of course, Fusion immediately failed me on that simple task, uuggghhh...
  • I'm just getting an error that says operation failed when I try to create new project.  It doesn't say anything about usage limits.
  • my old projects are still available
  • when I go to help/about it says (Active plan: Fusion 360, Subscription)
  • log file attached
  • PLEASE HELP!
Message 6 of 19
I appear to be having the same problem.  I am a new to Fusion 360 and I am listed as a "Active Plan: Fusion 360  Startup" user expiring in 2020.   I have been going through the tutorials and want to try things out.   When I enter a name to  create a new project  I get the message "Operation Failed".       I can still  access old projects.   My diagnostic file is attached.   I would appreciate any direction you can give me.
Message 7 of 19
I am having the same problem.  I am a new user just getting started on Fuson 360 with  a Startup license.   I can create new sketches in the existing Demo Project folder, but I get the message New Project Operation Failed if I try to create a new project.  Diagnostic report is attached.
Message 8 of 19
saito.kh
Autodesk Support
Autodesk Support
Hi @Anonymous,
Thank you for posting in the community!
Sorry to hear that is happening.  Can you please go to login.autodesk360.com and try signing in?  Are you able to see or create projects there?  If not, can you share some screenshots of any errors you have?
Thanks.
Kanehiko SAITO
Message 9 of 19
Hi!
Due to the license changes, I had to re-activate my free personal license. Now when I log in, I'm not able to create anything. No directory, no project, no file. All I get is 'Unavailable with basic access'. How do I get this to work again?
Thanks in advance,
Michael
Message 10 of 19
I have the same issue, log files attached
Message 11 of 19
Same is happening to me.  I haven't used F360 in almost 4 years (Feb 2016) and it refuses to create anything new.  I just looked and it says "usage limit exceeded" and I have never used any of this stuff.
Log stuff is attached.
Message 12 of 19
The same problem (Operation failed when try to create New Project).
Signed up for "Pesonal" plan 3 days ago.
Sync is OK in "MyName's First Project", can create folders inside this project.
Tried on 2 MacBooks.
Message 13 of 19
For me I had to make a team as personal folder will only allow one. Basically they want everyone using teams.
Message 14 of 19
Thank you!
I couldn't find how to create Team inside the app, but find this option on the web.
They suggested "3- days trial" for the Team site. Does it mean that Team option is not free for Personal license?
Message 15 of 19
Message 16 of 19
I have the same problem (personal license)
Message 17 of 19
I've creating project err.
Message 18 of 19
brunokc
Hitting the same issue. About 2hrs ago I renewed my license (personal/hobbyist) after not using Fusion 360 for over 6 months. For a while Fusion 360 showed "Expired: Subscribe now" but after waiting for quite a bit, I was finally able to login without errors. Now I can't create a new project. It says I reached some limit but it doesn't tell me what the limits are. I'm now stuck.
Is there a fix for this problem?
Message 19 of 19
Phil.E
Please confirm the following:
Try the remedies on this article:
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/Can...
FYI, how to set up a team hub:
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/How...
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
