New Folder
New Folder
MichaelT_123
Advisor Advisor
New Folder
MichaelT_123
Hi TF360 & FFellows,
I was in the process of creating the design's New Folder ... however, the process seemed to be interrupted in the middle ... resulting in an inactive/unresponsive New Folder entry on the design's project palette. Additionally, I can't delete this entry (as it is unresponsive) or create a new New Folder ... anywhere.
The failed New Folder always floats on the top of design palette window.
I can open existing designs ... which is great !!!
Any advice ... ?
Regards
MichaelT
MichaelT
a.laasW8M6T
Hi
This happens to me quite often
I have found in the first instance you can try navigating Home then back to the Project/Folder you were in and the "New Folder" will either no longer be present or will now be selectable.
The next method is to close and restart Fusion.
Either way is annoying, to me the Data panel is quite possibly the worst feature in Fusion its very slow and buggy.
Andrew Laas
Senior Machinist, Scott Automation
vinayak_dhame
Hi @MichaelT_123 , @a.laasW8M6T ,
Sorry to hear the issue that your facing. We already have the ticket for this issue ,but the issue seems to be very inconsistent .
Could you help us with capturing a video for this and share with us which can help us to fuirther investigate on the exact steps to reproduce.
Vinayak Dhame
Autodesk Fusion
MichaelT_123
Hi, Messrs Vinayak Dhame, A.LaasW8M6T,
Here is the corner of the FScreen. The red markers indicate inactive areas.
Go Home and Back did not work Mr. A.LaasW8M6T.
I will check with rebooting the system later on; I can't do it now due to some work in progress. I will definitely pursue the tip … and share the result.
Thanks & Regards
MichaelT
MichaelT
MichaelT_123
Hi, Messrs Vinayak Dhame, A.LaasW8M6T, FFellows,
... excellent news ... rebooting the system fixed the problem ...
which perhaps was due to an unstable network connection, breaking process of New Folder creation.
Perhaps, some kind of the New Folder transaction envelope could alleviate the issue.
Regards
MichaelT
MichaelT
vinayak_dhame
Hi @MichaelT_123 ,
Thank you for sharing details. We will investigate further and update here once the issue is fixed.
Vinayak Dhame
Autodesk Fusion
