Named views for Exploded model in Fusion.
tomek8X84H
tomek8X84H
After November 2024 Product Update Fusion stopped saving the view when switching from Animation environment to Project (and back). This problem was reported to me by several clients in Poland (I am Autodesk Certified Instructor). I am attaching a video showing that even overwriting in the view cube is not remembered and the cube is independent in both environments.
Until the last update, after setting the view in the animation environment, you could go to Project and save the set user view as "New Named View (to insert this view into flat documentation). Now there is no possibility to insert a custom named view that was precisely set for the exploded view. For my clients, this is a total regression and makes it very difficult to create assembly instructions.
bwalker145
I'm having the same issue, cannot create a custom named view for the exploded orientation.
Is there a way to revert back to the previous Fusion version until this is fixed?
tomek8X84H
@bwalker145    Update v.2.0.20962 – November 25, 2024  fixes this problem.
Thank You Fusion Team!😀
