Name a dimension
Name a dimension
jumpingryan
Name a dimension
jumpingryan
When I dimension a sketch if comes with a name like "d1"
Is there any way to quickly click on the dimension and name it. Having to go to parmeters and type "d1" and then close the window.
HughesTooling
When you create a dimension you can enter something  like name = 10.
If you have already created the dimension and you want to name it there's a bit of a problem where this only works if you change the dimension size.
So if you have an existing dimension of 100mm and you type Name = 100mm it will not rename the parameter but if you enter Name = 99mm it will rename the existing dimension.
@Phil.E This bug seems to have been around for a long time, is it logged OK?
Mark Hughes
Owner, Hughes Tooling
Phil.E
Thanks, looking into it. I've asked the sketch team to respond.
It only happens with sketch dimensions. Solid commands like extrude do not have this issue.
Phil Eichmiller
Software Engineer
Quality Assurance
sameer_babarNJS6C
Sorry for the inconvenience caused . We can reproduce the issue as mentioned in above discussion.
We have logged an issue(FUS-162106) for it & our team is looking for the solution .
Sameer Babar.
Autodesk Fusion Team
