Move with copy does not work on text in sketch
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
If you create some text in a new sketch, you can copy it by selecting it and use CTRL+C and CTRL+V.
But if you use M (move) and select "create copy", it only copies the frame (see below - the second text is copied with copy paste and the lower one with the M (move) command.
By the way there is a bug when showing the copy menu - when the source is the upper one the window becomes too small:
If you select the second or lower as source the move windows is normal size
