Move/Copy no longer works
seancairns
seancairns
The Move/Copy command used to work pretty flawlessly, choose what you want to move, axis and rotation handles show up, simply grab the one you want to adjust and drag. It was quick  and intuitive. Now the feature looks the same but it's impossible to  grab the handle you want. If I want to move, it'll rotate or move in the wrong axis, if I want to rotate it'll move on some arbitrary axis. The error occurs in all camera views (ortho and perspective). This is really hampering productivity.
This is my setup:
Fusion 2.0.19215 x86_64
Active Plan: Subscription
Windows 10 Pro 22H2 (19045.4412)
Here's a video demonstrating the issue
HughesTooling
Works as expected for me. Are you using a SpaceMouse?
Mark Hughes
Owner, Hughes Tooling
seancairns
A 3D Navigator, yes. Not sure how that would affect my ability to select a handle and drag though. I'm not trying or expect to be able to use the Navigator to rotate.
HughesTooling
I was only trying to see if you had something different to what I have. Is there a quick way to disable the 3d Navigator just to see if it has an effect? Probably best to close and restart Fusion without the Navigator. Other option to try might be select a different graphics driver in Fusion.
Mark Hughes
seancairns
Well done, sir! I didn't disable the Navigator but it was set to legacy instead of latest. I also changed the graphics driver to Auto-select. I'm not sure which change got it working again but my life just got a little easier. Thanks!
g-andresen
With a 3D Connexion device, the "Latest" driver selection occasionally leads to the unintentional locking of the horizon (Lock Horizon).
This problem can be avoided with the "Legacy" setting.
günther
