Modifying printed Labels
chrisrobertson78
chrisrobertson78
Evening all,
I have just bought a Dymo Label Writer 5XL and are trying to change the template for ASSETT/NESTLABELS TEMPLATES
It has a label size of 54mm x 101mm. I router many parts and thought this would be an easy thing to change but my fusion has very limited labels in templates.
Can someone point me in the right direction
Thank you
Chris
g-andresen
I think you are in the wrong forum.
Fusion 360 is a CAD application.
günther
chrisrobertson78
Fusion 360 Nesting and Fabrication has ability to print labels and detailed nesting sheets
g-andresen
I have not yet dealt with this
günther
autodesk2YJ3JU
Hello!
I have the same problem.
If you go to All project -> Assets -> NestLabelsTemplates -> Open on the web (little earth icon with an eye)
It will open in your browser, you can download any template you like.
Then you have to modify the html with any text editor.
I modified everything to mine label printer (Bixolon with 100mm x 60mm label)
But it just did not work. The text on the label is not fitting the correct size.
If someone got this to work fine please let us know!
Thank you!
chrisrobertson78
I’m working through this with autodesk, I’ll let you know if they can provide a solution. It’s been a while in the making. They really don’t know
scott74UCF
Any update?
When i click the download button it directs me to a page not found URL missing page
