Modify a Draft
Modify a Draft
tylerruffellCYQDF
Modify a Draft
tylerruffellCYQDF
Is there a way to change the angle of an existing draft?
jhackney1972
You did not attach your model but if you are Capturing Design History, go to your timeline and right click on the Draft and select Edit Feature.  Add it your model if you want for a clear explanation of what you need to do.  If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it.
John Hackney, Retired
