Model surface flickering when custom appearance applied
hamishsw
Observer Observer
hamishsw
Observer
Observer
I am using the animation features to create short clips showing parts coming together. However moving the camera or moving components and then restoring home causes very noticeable flickering on the component surfaces.
This is only an issue when I use a custom appearance where I have used downloaded images to simulate the appearance of plywood. I have attached an example.
Is there a way to prevent this behaviour while still using a custom appearance? Perhaps I can make changes in the materials editor?
Many thanks
hamishsw
Observer
Observer
Update -
I deleted all the appearances I had created an tried again with zero reflection. While I do not want to jinx myself, that may have worked (fingers crossed).
