Model Parameters Missing Missing Constructs
Johns_Fusion_Account
Used a User Parameter for an offset plane distance, thought it show up in the model parameters, could only find the values by right clicking the offset plane in the browser and clicking edit feature.
Is there a way to make this and all other model parameters show up in the parameter screen?  It would be nice if they could all be accessed the same way in the same place to facilitate changes.  Currently it only seems the sketch parameters appear in the model parameters section.
jhackney1972
I do not see your issue.  I created two workplanes and the values for both show up in the Parameters Table.  One was a rotated plane angle value and one was a distance from a face value.
John Hackney, Retired
Thank you, I am attaching screen shots of what I am seeing, I will try it
from another plane, and not the origin plane tomorrow as I have done in my
design.
I am attaching screen shots of what I see in my design showing it is
missing, perhaps some odd coincidence causing it to happen, something to do
with it when right clicking on the offset plane, it goes into the sketch
with the side I used to create the offset plane from.
Thank you for looking will work on steps tomorrow...
