Model drawing to Illustrator
dfitterman
dfitterman
I create 3D models from a rectangular prism that is cut with a series of planes.
Part of the prism on one side of the plane is discarded. The retained portion repeatedly cut in a similar fashion.
I want to fabricate the model with cardboard and if I like the design with sheet steel, cutting a piece for each face.
How do I create an Illustrator (or other graphics program) readable file for each face of the prism?
I have tried selecting a face and creating a drawing on the face, but I can't figure out how to export it as a DXF file.
g-andresen
Rightclick sketch > save as DXF
günther
TheCADWhisperer
Click on the face and select New Sketch.
P for Project (Geometry) and select the face (and any island faces if necessary).
Right click on the sketch and Save as DXF as indicated by @g-andresen
(If the sketch already exists, then no need to create a new sketch as described above.)
I then print out and paste onto thin cardboard that I use as a template for hand scribing and cutting the material.
If the part is too big for my printer - I add registration marks to multiple prints so that I can tape them together.
Attach your file here if you can't figure it out.
dfitterman
Thanks, that worked. Is there anyway to easily do this for all of the faces at once?
g-andresen
You can project all surfaces in a sketch that lie in the projection direction.
günther
