Missing Timeline and model Components
andrew.macvicar
Message 1 of 12
andrew.macvicar
Urgent use of this model is required - Please help! Not one of the solutions previously posted are 'solutions' in this case:
  • Timeline is missing from blank page, also viewport control icons missing at bottom of the screen.
  • Opening the model (model of new house v59) shows half of Components are missing, and no timeline / controls as above.
  • Capture Design History is ON (I can toggle option to turn off)
  • Preferences set to Capture Design History
  • View: Reset to Default Layout - does nothing
  • Reset Windows Explorer does nothing
  • Restarting F360 / Windows does nothing
  • Viewport appears to be very slightly larger than it used to be, however I am reluctant to change screen resolution because it messes other things up (Windows 10 auto selected to 1920x1080 )
  • Nvidia GeForce 940MX: driver is updated / Windows drivers updated
See attached FULL SCREEN view to compare size - it seems just slightly larger and I think this has something to do with the issue.
Replies (11)
Message 2 of 12
seth.madore
Have you toggled between Windowed and Fullscreen and then back?
Seth Madore
Message 3 of 12
andrew.macvicar
Im looking how to do this - can't seem to find the option in the F360 program or Windows Display settings. Can you please advise?
Message 4 of 12
andrew.macvicar
There are no visible viewport control icons at the bottom of the screen (they are missing)
Message 5 of 12
seth.madore
Seth Madore
Message 6 of 12
andrew.macvicar
I found it - now recovered everything! Screen size returned to normal and everything is back. Model recovered, many thanks!
Message 7 of 12
g-andresen
Normally, posts that have provided clues to the solution are marked as "accepted solution".
In this case it is the hint #2 (#5) by @seth.madore
günther
Message 8 of 12
andrew.macvicar
Hi - yes - this worked, and much appreciated.
Message 9 of 12
seth.madore
Or I can just do it myself 😄
Seth Madore
Message 10 of 12
Phil.E
Logged as FUS-119447.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 11 of 12
Leo.Litto
Thank you! I had the same issue and this simple fix worked. Boy do I feel like a dummy...
Message 12 of 12
andrew.macvicar
I have found it is too easy to overthink the problems when so much is at
stake, like a 100 hour model! Glad to have brought this to light for
everyone else...thanks.
