Missing Qt6Widgets.dll
schultz.rick2
Message 1 of 12
schultz.rick2
Anyone have success fixing or replacing a missing Qt6Widgets.dll file?
I have been having some weird connection errors while working online.  Randomly Fusion will drop its online connection and usually comes back on.  I have tested my network and I can say that the issue does not appear to be with my actual network as its running as it should.
last night I had the problem and I was not able to reconnect. I went a chose repair fusion from the dashboard.  The repair process failed and I lost the Qt6Widgets.dll in the process.
Now I am unable to launch Fusion. When I attempt to launch fusion I get the missing dll file error and a suggestion that reinstalling Fusion may fix it.
the screen shot of the error is attached.
what is the correct procees to fix this problem?
Thank you,
Rick
Replies (11)
Message 2 of 12
g-andresen
might help
günther
Message 3 of 12
schultz.rick2
Will uninstall effect file data and team member connections?
Message 4 of 12
pdifflipp
I am having the same exact problem, it was running fine yesterday afternoon, now this morning I am getting the Qt6Widgets.dll window
Message 5 of 12
schultz.rick2
@pdifflipp
As others have suggested,
I would try uninstalling fusion and reinstalling fusion. It worked for my situation. There are a few hidden files that may need to be deleted after the uninstall, prior to reinstalling fusion.
I believe there are posted links to resources posted earlier in this thread.
If you cant find those I would follow the Autodesk guidelines for uninstall and reinstalling.
Rick
Message 6 of 12
pdifflipp
Thanks, Rick!
I did try uninstalling then reinstalling but received an error message while it was installing. I posted the log file . I am guessing I might have a permissions problem because of our IT department.
Thanks again, Paul
Message 7 of 12
schultz.rick2
Yea if you have an IT department I would have them help you though the
process.
I have a single seat license for my small shop. No IT department.
Message 8 of 12
rocycling
Community Visitor
Community Visitor
Has someone found a fix for this?  As of a few days ago I'm having the same issue.  Attempting to load the service utility shows the same error.  Re installing Fusion did not fix the problem.
Message 9 of 12
alexmagnetti
same problem
Message 10 of 12
dgutierrezFU7F8
Community Visitor
Community Visitor
I can't open de Service Utility command to repair Fusion 360, when I try it, have the same error with dll s.
Message 11 of 12
justinnorris2010
Community Visitor
Community Visitor
anyone solve there issue i am having same problem now
Message 12 of 12
tooljunkie
Community Visitor
Community Visitor
I am having the same issue. I have tried all the suggestions without success.Hope someone fixes the problem soon, it is a pain.
