Misplaced joints in mirrored components
bpitanga
Message 1 of 9
bpitanga
I have a design (a robot claw) with some lateral components tied with joints to a central component. After I mirror the lateral components the joints are lost, which I´m aware it´s a normal Fusion behavior. The problem comes next: after I reapply a joint on a mirrored component, it seems to behave OK on the preview, but, after I click OK, the joint appears on a different place that seems to be related somehow to the original component. (see the screencast attached).
Am I doing something wrong, or is it a bug?
Thanks in advance.
Bruno
Replies (8)
Message 2 of 9
bpitanga
Seems the screencast wasn´t attached to the previous message and if I try to edit the message now, the option is no longer available. See if it goes here.
Message 3 of 9
bpitanga
Couldn't find a way to erase my previous message. At least I've discovered how to attach the screencast.
Message 4 of 9
jeff_strater
Interesting.  Thanks for sharing the screencast.  Yes, that looks like a bug to me.  Can you share the design with us?  Then we can further investigate this bug.
Jeff
Jeff Strater
Engineering Director
Message 5 of 9
TrippyLighting
@jeff_strater Yes, this is a bug, but that's already been reported in two threads as FUS-33516
Message 6 of 9
Beyondforce
Wooow, this is crazy. I have the same problem right now with one of my models. I thought I might doing something wrong.
It's good to know I'm not a 100% an idiot (98%) 😉
Cheers / Ben.
Ben Korez
Fusion 360 NewbiesPlus
Fusion 360 Hardware Benchmark
| YouTube
Message 7 of 9
bpitanga
Here is the design file. Thanks for the attention.
http://a360.co/2iShlO5
Regards.
Message 8 of 9
jeff_strater
Thanks for sharing the model, @bpitanga.  It always helps to have more test cases, to make sure that the fix covers all of them.  This bug is our highest priority right now.
Jeff
Jeff Strater
Message 9 of 9
TrippyLighting
Thanks for the feedback. That's good to know!
