Mirroring in sketches causing crashes
HarrisonClassic
HarrisonClassic
I've noticed since upgrading to the latest Fusion release that I'm starting to get more than a few application crashes when I attempt to mirror sketch objects.
This is in the same model I have been using through the last several releases of Fusion.
I see old postings in the forum about this issue, but nothing recent.
Am I the only one?
Fusion 2.0.10244
Active Plan: Fusion 360, Subscription
Windows 10 (19043)
David Harrison
Harrison Classic Boats
Win 10 / I7-11700K @ 4.9GHz / 64Gb RAM / SSD's
g-andresen
Please share the file. >  Mark the elements to be mirrored
File > export > save as f3d on local drive  > attach it to the next post.
günther
jeff_strater
I'm not aware of any general new crashes in sketch mirror.  I see 4 crashes from you in the past couple of days, all definitely in sketch mirror.  Are these all in the same design, same sketch?  As @g-andresen says, we really need the model and an indication of which curves you are mirroring.  It could be specific to this sketch, or there could be a more general problem.  Either way, having a way to reproduce the crash is the fastest way for us to try to fix this.  Thanks.
Jeff Strater
Engineering Director
