Mirror Warning/Error
realp27606
realp27606
Not able to mirror holes across a plane in my bookshelf.  I have tried all mirror options, adjust, identical and optimize. I get a warning "compute fail no target body" with the first two options and an error using the last option.
Here are a couple of screen pics
 I have uploaded my F3D file as well
jhackney1972
You are trying to Mirror features between two components with unique bodies.  This is not possible.  Activate the Middle Side, create a sketch on the face you want the holes, project the two at the bottom from the Left Side component and then pattern as desired.  By the way, edit the holes, in your model, in the Left Side to reveal an error in their depth.  Model is attached.
John Hackney, Retired
realp27606
Thanks John
Well with a program so rich in feature there are always something to learn
Thank you so much
