Mirror (Features) Issue
I've been learning the software and have had good experiences with the multitude of YouTube videos out there to help me along the way.  I'm trying to learn to group actions in my timeline to better track my steps.  As I progressed later into this design, I was having a problem with mirroring.  I slid my timeline way back to ensure the problem was not introduced during some later steps.  At the point where the video starts, the actions I took so far were:
Sketch/Extrude on Default Plane
Create Offset Plane
Sketch/Extrude on Offset Plane
Create a Loft between the two
Create a shell
Extrude the bottom out of the body.
Split the body (top/mid/Base)
I draw a simple sketch on one of the faces and extrude a hole from the object to the other side of the object.
I then mirror the Feature using a default plane, and the "preview" shows it will go where I expect it to. The problem is, a hole gets blown partially in the base.  I don't understand why?
jhackney1972
You attached a .mkv file, what is this?
John Hackney, Retired
Sorry... corrected.  🙂
g-andresen
Please share your design file (f3d) and name the relevant elements and their expected behaviour.
günther
