Mini PC -vs- Desktop PC?
Hi. I’m new to the forum and looking for assistance please.
I'm in the process of purchasing a new PC for home use and hobbyist Fusion 360 use.
I’ve shortlisted the two following systems within my tight £300 budget
Dell 9020:
  • Intel Core i7 – 4790 / 3.6GHz
  • 8GB DDR3 SDRAM
  • Integrated Intel® HD Graphics 4600
  • 500GB HD
  • Windows 10
Beelink U57 MINI PC
  • Intel Core i5 - 5257U / 3.1 GHz
  • 8GB DDR3L
  • Integrated Intel® HD Graphics 6100M
  • 256GB SSD
  • Windows 10
Questions:
Q: Is a MINI PC with the above spec suitable for running Fusion360?
Q: Is a MINI PC a viable alternative to a desktop for Fusion360?
Q: Any opinions please on my shortlisted systems?
I can’t find much forum chat on the use of MINI PC’s so I’m guessing they aren’t a popular choice for Fusion.
Thank you in advance.
kelbie.ockey
Here are the recommended min specs. Going purely off of this, it seems that both should be suitable.
I'm far from a PC builder or pro on all thing components, but just simply looking up some benchmarks, etc., it seems that the desktop may have a slight edge in several categories. I'm not personally super familiar with mini's, but I would imagine that a standard desktop would likely be easier to upgrade down the road as well, if that's something you foresee coming up.
If you have other reasons for wanting the mini, I wouldn't feel bad about it. As I mentioned, both seem to at least hit the minimum recommended specs. Maybe someone with some personal experience can chime in on that front.
Hopefully, that's helpful. LMK if not.
Kelbie Ockey
Sr. Implementation Consultant
TrippyLighting
The desktop will have the upper hand for two main reasons:
  • CAD applications (not just Fusion 360) are mostly single-core. The math and algorithms don't lend themselves to parallelization, so the higher core clock frequency is of advantage.
  • The desktop is easier and likely less costly to extend with a dedicated graphics card. This might also apply to upgrading memory.
    I'd check how easy it is to upgrade the mini-computer. IF there are memory modules available and discrete graphics cards then it might be a good choice.
In my not unsubstantial experience with Fusion 360, 90% of the people who experience performance problems, follow not recommended modeling techniques. So in the end it might really not matter all that much.
Rendering on the other hand uses every bit of computing power you can throw at it. Number of cores, clock frequency, It'll eat everything you've got regardless how much you've got and it's never fast enough 😉
Hello Kelbie and Trippy. Many thanks for your thoughts and guidance. I have limited PC construction knowledge but my instinct told me that the desktop would possibly be more flexible to upgrade, as and when my Fusion skills develop. The specs on the mini PC are attractive, particularly when on a small budget. But I found it curious why there wasn't more discussion on the web about how they perform with 3D modelling applications. Anyway, thanks to your combined advice along with  some significant research on the desktop I decided to purchase the desktop.  Thanks again both.
