Midpoint constraint not working on arc
The midpoint constraint does not seem to be working correctly on this sketch. Am I doing something wrong? is there a better way to do this? I cant seem to use the tangent constraint either.
davebYYPCU
Doesn't seem right, wheres the browser, blue highlight in Timeline missing,
Share the file....
g-andresen
It works as expected.
Screencast
günther
here is the file
HughesTooling
Looks like the equal constraint is causing the problem. When you have 3 tangents and 2 parallel constraint both arcs will be the same. Also the sketch is in 3d and I don't think the 3d sketch solver works as well as it does in 2d. Personally I create a plane in the correct place and create a 2d sketch on the plane.
Mark
Mark Hughes
Owner, Hughes Tooling
