Mesh to Brep Missing
garrett_carroll65
Message 1 of 46
garrett_carroll65
I can not seem to find where the Mesh to BRep option was moved to. It is not available in the search function, I have the design history turned off and am in the mesh work space.  I am on version 2.0.3802 and using Win 10 Pro.
This is a feature I have used in the past and I did find a video on youtube that was uploaded today show how to do it but they were using mac.
Anyone have an idea as to what is happening here?
Replies (45)
Message 2 of 46
James.Youmatz
Autodesk Support
Autodesk Support
Hi @garrett_carroll65,
Welcome to the Fusion 360 community!
It's been a while since I've used this command, but I believe it's located in the Model environment, under the Modify menu.
James Youmatz
Product Insights Specialist for Fusion 360, Simulation, Generative Design
Message 3 of 46
garrett_carroll65
I wonder when they moved it, I watched a video that was posted yesterday to youtube and it was in the mesh area to make the conversion. Also where it was the last time I used it.
Thank you for showing me the new location.
Message 4 of 46
rogueiq
I'm struggling with this same issue. I am in the model environment, but compared to the screenshot shown I am missing both the "convert" button and the "mesh" sub-menu in my Modify drop-down.
Message 5 of 46
James.Youmatz
Autodesk Support
Autodesk Support
Hi @rogueiq,
Is the timeline enabled or disabled? The mesh environment is a direct modeling only procedure, so the timeline needs to be off. To do this, please refer to this guide here
Alternatively, if you do not want to fully disable the timeline, you can select, Create->New Base Feature to temporarily go into the direct modeling environment until you finish the base feature.
James Youmatz
Message 6 of 46
rogueiq
I had not been aware of that requirement. disabled and there it was, thank you!
Message 7 of 46
doug_bailey
Observer
Observer
I'm having a similar issue with "Mesh to BRep" not showing up.
I downloaded the "Applecore" stl file from Thingiverse - it's an apple core shaped bobbin to wrap charger cables around to keep them tidy.
However, the new C-to-Lightning cables don't fit in the slot, so I want to widen it. My intention is to convert from the stl to Brep and then edit.
But after "opening" the stl, and turning off history, I don't get the option to go to B-Rep in Convert, only T-Spline. And the conversion breaks because the stl has triangles in it and won't convert to splines.
Any idea what happened to the B-rep conversion feature in this case?
Message 8 of 46
James.Youmatz
Autodesk Support
Autodesk Support
Hi @doug_bailey,
It is in the Modify menu under Mesh:
James Youmatz
Message 9 of 46
josephgeek
 This feature appears to have moved again. The mesh editor is now a preview feature. Does this exist any more?
Message 10 of 46
It is missing until you turn off capture design history.  It would be much less misleading to grey out the Mesh to BRep option with design history turned on.
Message 11 of 46
now with the new update of fusion 360 i can't find mesh to brep anymore...only possibility is brep to mesh...
How will it work in the latest update?
Message 12 of 46
I had the same issue on the latest version 2.0.6. I couldn't see option to convert "Mesh to BRep" (stl objects to solid)
I had to disable the timeline by "right-click" on the root component and then "Do not capture Design History".
Message 13 of 46
garrett_carroll65
Why does no one look at the date on the original post?
This was solved years ago..
Message 14 of 46
Beste,
hier mis ik ook de functie mesh to Brep.  Heb de tijdlijn uit, en de mesh omgeving in preferences aangezet.
kan de edit functie mesh wel gebruiken, kom dan in menu mesh. Kan dan alleen vanuit component naar mesh.
Weet iemand of dit een instelling is?
Vreemd, dat in het menu onder modify geen mehs beschikbaar is, zie foto
Message 15 of 46
g-andresen
günther
Message 16 of 46
also not available with right click, see picture.
Message 17 of 46
g-andresen
First:
günther
Message 18 of 46
PhDEdd
This is so ****ing stupid.
Why do you have to turn off design history to make the option visible? This is one of those things that takes 30 minutes of Googling for NO reason other than for terrible UI design.
Not to mention the locations of things changes. The "Model" menu doesn't exist anymore.
Message 19 of 46
TheCADWhisperer
Bothered by change?
Uhm, well...
Message 20 of 46
PhDEdd
More bothered by poor UI.
Thanks for your insightful reply.
