mesh texture disappeared
hansC56SA
hansC56SA
I successfully imported some mesh objects that I scanned with iphoe LiDAR with their texture, rearranged them and started to model from them.
just eventaully all the textures disappeared. Maybe this was happening when I saved the project while offline and then reopened it...
When I import a new mesh into the same component it shows with the texture.
Where are my textures????
Phil.E
Hi. Thanks for posting.
I'd like to try to reproduce what you are describing. Can you share a sample of this data?
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
hansC56SA
great if you can have a look!
I deleted everything from the file but two meshes. One that lost the texture and the other one a fresh import of the same data.
Phil.E
Thanks for the file, but I'm not entirely sure what I'm looking at.
This is how the file opens. A pink and purple body. The pink one is the "lost texture" body.
I was hoping to see the scan data that produces these bodies. In order to debug this we need:
1. The inputs (the original scan)
2. The expected result (a picture of the expected textures)
I can use this information to find out what happens when Fusion uses scan data like this, and hopefully get an answer for you. If I find a bug, I'll log a ticket and respond.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
