- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
When merging two mesh bodies say A and B, A cuts into B and thus part of B's surface is covered by A, However Fusion 360 does not remove the surface where A penetrates B. I have had to delete the surface manually.
A=Open ended cylinder. One end is closed
B=Sphere
A is merged with B but to remove the intersection between the two surfaces I had to delete the section of the sphere in the intersection manually.
Is this a short coming in Fusion 360 ? Please don't tell me to convert to BRep first. Fusion 360 should be able to manipulate the mesh bodies directly.
