Menus, key shortcuts and confusion.
mark33.in.oz
mark33.in.oz
Ok, newbie here......
I have found this problem with other programs too, but I want to check it isn't me.
Sketch/Line.....   'L'
Sketch/Rectangle (2 sided).....   'R'
Create/Extrude.....  'E'
L, R, E?
No, they are l, r, and e.
I hold the SHIFT KEY down and press the L, R or E and wonder why it doesn't work.
Why can't the program show the REAL key press needed?
Another one which has made me laugh many times over when I see it is Ctl <Shift> +
When it should be Ctl <Shift> =
Or:
Simply:
Ctl +
jodom4
Hey mark33.in.oz,
Thanks for the feedback. You can also make custom keyboard shortcuts, this might improve your experience: https://www.autodesk.com/products/fusion-360/blog/quick-tip-custom-keyboard-shortcuts/
Jonathan Odom
Community Manager + Content Creator
Oregon, USA
Become an Autodesk Fusion Insider
mark33.in.oz
Hi.
(Should have mentioned this when I marked it as solved, but.....)
Although you have explained/shown me that I can define keys, the issue that to create a 2 point rectangle the menu says it is 'R' when really it is 'r'.
