Measuring a length between 2 points
david.carlsen
david.carlsen
I just want to click point a and then click point b and be told the distance in the framework within which I'm working. Not between two objects or such just an arbitrary point a and an arbitrary point b. Two dimensional on a face using a canvas to pick the points which currently do not relate to any object constructed.
jeff_strater
this is not possible.  You can measure between two model vertices, work points, or sketch points, but not between any to arbitrarily clicked points.  I'm not sure I understand why you would need to do that.  It seems like such a measurement would be unreliable, depending on where you picked.
Jeff Strater
Engineering Director
david.carlsen
thanks I figured that was the case. Long story, I'm calibrating a canvas after having already having done some sketching then scaling the sketching just wanted to do an arbitrary check on the canvas in a couple places to see how it all went. I'm a beginner and just randomly jumping the gun on working on a project because really, who has a couple years to do tutorials.
jeff_strater
ah, calibrating a canvas...  This is actually one area where you CAN pick random points and measure (or adjust) the distance.  Right click on the canvas and choose Calibrate:
then, you can pick any two points in the canvas and measure, or set a new measurement, for those two points, and scale the canvas to whatever size you want:
Jeff Strater
