measure tool incorrect or drawing error ?
kontaktA44SC
kontaktA44SC
Angle of 29 was defined - how about the other result from measure tool?
Both should add to a 180 !!!
TheCADWhisperer
@kontaktA44SC
Missing Horizontal or Colinear Constraint on the object line.
None of your geometry is fully defined.
Blue lines and white dots should keep you awake at night.
In addition to missing Horizontal/Vertical constraints - it appears that you are missing a Tangent constraint too...
kontaktA44SC
🙂 so that why i have trouble going to sleep early - thanks now i know a little bit more 🙂
