Measure bug
Measure bug
FrodoLoggins
Advisor Advisor
Message 1 of 15
Measure bug
FrodoLoggins
https://youtu.be/XfCYgFGAEyY
- Time Magazine’s Person of the Year 2006
- Apple M1 Max rMBP A2485 // Latest MacOS // Latest Fusion
- Usually working off files uploaded to Fusion as: Step, STL, SLDPRT. If it matters ask me.
Replies (14)
Message 2 of 15
Phil.E
The video is really fast and doesn't explain much. What are you trying to measure, and what is the bug?
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 3 of 15
HughesTooling
@Phil.E  The bug is the odd dimension you get if you select the cylindrical boss and the flat face. I've seen this a few time lately in my designs but not had time to create a design I could share.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 4 of 15
Phil.E
I could see that. What is not clear is what the intended result is. Why pick those two inputs, and what is the desired result rather than this odd dimension?
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 5 of 15
HughesTooling
Should give you min and max distances plus centre line to plane like this.
Mark
Mark Hughes
Message 6 of 15
HughesTooling
@Phil.E  Here's another example from one of my designs. I've only exported the component so ignore the warnings in the timeline, they don't affect the measure bug. File's attached.
Mark
Mark Hughes
Message 7 of 15
Phil.E
Thanks for explaining. Got it logged now with these examples.
(ref: FUS-66786)
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 8 of 15
Phil.E
Hi again. This week Fusion 360 had a major update to build 2.0.8749. This bug should be fixed in this latest update. Please update Fusion and let me know if you still find the same problem.
Verifying build number:
  • Help > About
  • Look for a number like "2.0.8XXX" in the about box.
  • Current build is 2.0.8749
Updating Fusion 360:
  1. Start or restart Fusion
  2. Look at the Job status icon (the small clock in the top bar)
  3. If an update is downloading a small 1 appears on the clock.
  4. Click to see progress and restart message when it's done.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 9 of 15
FrodoLoggins
Seems fixed, thanks.
Message 10 of 15
FrodoLoggins
Possibly similar bug, the measurement should be square to the selected face not at an angle:
Build: 2.0.9142 on MacOS
Message 11 of 15
FrodoLoggins
kuvllkjvjkvlk
Message 12 of 15
Phil.E
Thanks for the model, the team is looking at it.
Note: if you reverse the selections (plane then edge) it performs correctly.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 13 of 15
Phil.E
The Fusion 360 update today carries a fix for this problem. Can you please try it out and let us know what you think?
To receive the update:
1. Restart Fusion 360
2. Wait for the update to start, you'll see a small 1 appear on the job status icon (the clock)
3. Click on the clock icon to watch the progress
4. Click Restart when the update is ready
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 14 of 15
FrodoLoggins
Updated, same issue on another part:
Message 15 of 15
Phil.E
What workflow does this example represent? I can't figure out what you are trying to measure here.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
