Max/Min angles with rotate joint ?
keld.soerensens
keld.soerensens
I made a small wooden suitcase and used a rotating joint to open the top part - the lid.
It seems that it works fine, but a closer look will show that the lid can be closed too much so that an overlap with the lower part occurs
If I look at the hinge alone it can NOT close too much !
The upper / lower part of the suitcase is rigid with the corresponding flap on the hinge.
Any ideas why and how to correct it ?
Here are a link to the drawing:
https://a360.co/2QKGJCJ
(I get a message that an illegal link is inserted - so I changed it to text - but it seems to work as a link anyway !
Why the this message about an illegal link ?)
Best regards
Keld Sørensen
Denmark
HughesTooling
Can you export the f3d and attach. I can't access those links at work. You will tend to get more help if you export the design and upload.
Thanks Mark
Mark Hughes
Owner, Hughes Tooling
keld.soerensens
I found out why - the flap on the hinge and the top lid was NOT parallel !
Best regards
Keld Sørensen
Denmark
