Marking areas
Marking areas
hofmesa
Message 1 of 10
Marking areas
hofmesa
I got an issue which come up a few days ago. If I want to mark several areas for extrusion as usual, they are no longer highlighted in blue. Can I reactivate this in the settings?
Thank you for the information on this
Replies (9)
Message 2 of 10
seth.madore
Would you be able to share your Fusion file here?
File > Export > Save to local folder, return to thread and attach the .f3d/.f3z file in your reply.
If you can't share your file, can you at least share some images of what you're seeing?
Seth Madore
Message 3 of 10
hofmesa
Thank you for your fast response,
usually when I want to do an extrude, I can choose every area of my sketch(this areas are marked in blue colour). But now there is no blue marking an I cant see what areas are choosen.
I haven't changed anything in the basic settings of Fusion360
Any ideas ?
Message 4 of 10
seth.madore
Seems to be working for me:
Seth Madore
Message 5 of 10
g-andresen
1. update your graphic drivers
2. TRY: Service Utilities > Repair
günther
Message 6 of 10
hofmesa
Hey,
does it work whne you whant to mark all areas with "ctrl" ?
Message 7 of 10
hofmesa
I installed the actuall graphic driver and do the repair like your instructions.
both doesn't work
Message 8 of 10
hofmesa
Hm I
done the reset in the service utilities and then switch graphic presets --> Limit effects
Now it works fine again.
Thank you guys for your tips and fast response.
Kind regards,
Bernard
Message 9 of 10
HughesTooling
You could also try the different graphics drivers in Fusion. This has worked for others.
Mark Hughes
Owner, Hughes Tooling
Message 10 of 10
g-andresen
please note in the future not to reply by "Post Reply" but to reply directly to an individual request.
günther
