making multiple copies of screws
cvbsDTXM7
cvbsDTXM7
hello,
  I am creating a wooden bench and I need several screws , bolts, washers , nuts etc.  I can find these in the McMaster area and down load, however when I go to make a copy I can only create one.  Once that is copied I can the select those 2 and make copies of them. Is there something I am missing in the copy tool that would allow for specifying number of copies to be made.
Thanks for all the help in advance.
g-andresen
Depending on the design, you should use the pattern tool.
günther
You can paste how many times you want the same file. You do not need to again copy 2 screw and then paste.
