Making holes in sketches
jackjmcinnes
jackjmcinnes
Hi There, getting to grips with sketcher, I have drawn the out line of my design, then added circles of which represent holes, when i export the file to dxf for the laser cutter, will it read the circles as holes? Am i doing this correctly or is there a better way of doing it? @jhackney1972
jhackney1972
Your DXF will pick up the circles, whether your Laser will interpret them as holes, that is up to your post processor.  Your DXF will contain all of your Construction lines, which may give you a problem.
John Hackney, Retired
Warmingup1953
I use a free Add-in to create good, almost universally readable .dxf files from the Planar faces of Solid Bodies:
DXF for Laser
It does a simple Projection to a new sketch in the background but then importantly for me, it (optionally) tidies up the timeline after creating the .dxf
jackjmcinnes
Thank you guys much appricated!
jackjmcinnes
Thank you John !
jackjmcinnes
Thank you, will give this ago!
