- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
It seems that a new UI bug has surfaced in this version. I'm on Mac with Mac OS X 10.11.6
I can't figure out the pattern to this unresponsive window issue. I'm trying get the actual event that kills the window. It happens quite often now.
It is very much an issue in sketches. Rollover highlighting doesn't work and you can't click on anything in the window. Even the view cube is unclickable at times.
I figured out a workaround for making the main window contents active again. I create a new design which adds a new document tab along the top of the window. Switching from the new Untitled design document back to the other design document seems to force F360 to make the main window active again.
- Noel
