macos 13.0 compatibility
ldhetrick7
ldhetrick7
Had to get a new system but it came with MacOS 13.0 ventura installed and now Fusion 360 will not even install. I've seen that OS is not supported yet but does anyone know of a workaround?
RajkumarIlanchelian
@ldhetrick7 @Are you getting any error on install? Does it give you a link to the logs on install failure? We are working on the full certification but I know a lot of customers have been on macOS Ventura for about a month now.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
ldhetrick7
It just says unable to install. I'll try to install again tonight and copy any other information I may have missed.
ldhetrick7
I uninstalled (even though I couldn't install) and re-installed and now it works fine. There must have been something that was partially installed that was causing the problem.
