Machine def BUG
Machine def BUG
daniel_lyall
Mentor Mentor
Machine def BUG
daniel_lyall
This pops up after you hit ok on a existing Machine def in inch
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
paul.clauss
Hi @daniel_lyall
Thanks for posting! I did not experience this issue on my end - would you mind clarifying the workflow that you used to trigger this visual problem? machdef.gif
Perhaps this is only occurring with a certain generic configuration? I hope this helps - if you are able to reproduce this issue please let me know.
Paul Clauss
Product Support Specialist
daniel_lyall
It does it with an empty project in inch
I have a screencast I can send you if you fix the ability to downloaded them or get a link, who ever said go for the forum update needs a good kick in the sack or fired
Daniel Lyall
The Big Boss
Mach3 User
paul.clauss
Hi @daniel_lyall
Thanks for the response - I am still unable to recreate this problem on my system. Please see screencast below.
Your screencast was working - not sure why it disappeared. I've had some issues with the forum update as well - I'll pass this along to the Lithium team. You can always just post the link to the screencast in the text area to work around this.
Does this behavior occur with any other machine configuration files? If it seems related to the one specific machine file, please share that .machine file with me. If it happens with all files, I would:
  1. Update your graphics drivers to the most recent available version.
  2. Perform a clean uninstall and reinstall Fusion 360.
I hope this helps! Thank you for bringing this to our attention.
Paul Clauss
daniel_lyall
The screencast sight is continuous stream of very rude and nasty words to use at the moment.
The machine def is attached, until the screencast sight is fixed I can not post the screencast it needs to be private I was just going to downloaded it and email it to you but I can not do that.
This stuff with the forum is making it hard to get some simple stuff done more rude words and nasty actions.
I need more coffee
What is your email @paul.clauss I finally got it to download
Daniel Lyall
The Big Boss
Mach3 User
paul.clauss
Hi @daniel_lyall
Thanks for posting. The forum update has caused some problems for me as well - the Lithium team is looking into these problems. As you come across them, please post in the Community Feedback forum to bring the issues to the attention of our forum/community management team.
I've been able to reproduce the issue with your machine configuration file - the issue must be something related to this particular file. I've logged CAM-9988 for our development team to investigate this further - please let me know if you need any help working around this visual issue in the meantime. We appreciate you bringing this to our attention.
Paul Clauss
