Machine Builder Help: Adding a quill to the machine kinematics
umairABV9U
umairABV9U
I have a Doosan DBC 110s horizontal machine model and I am creating a machine simulation for it using the machine builder. Everything is working well but I am having issues with adding the quill (W axis) inside of the machine sim. I guess I am unsure on how to structure the kinematics for it. When I try to put it under the Z axis it tells me Fusion already has a Z axis error. Can someone help me understand how I would map the kinematics in Fusion to add the W axis?
Thank you in advance.
Link to file https://a360.co/49wUPzF
serge.quiblier
Hello @umairABV9U
In its current state, the machine builder does not support colinear axis.
The post engine is also not supporting that functionality.
We are restricted to three linear axis (not colinear), and two rotary axes.
At the time, the kinematic is limited to these five axes.
Regards.
______________________________________________________________
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
Serge.Q
Technical Consultant
cam.autodesk.com
