Mac version update? import not working?
t_lamourine
t_lamourine
OK, just read the whole Mac version 10.11 thing, I'm on an older Mac, but using OS 10.13.6 High Sierra so tat should be good?
thing is a few of us share files and/or do quick mock up in TinkerCAD and were trying to use the direct import from T-CAD to Fusion and it gives me this "need to update" message.  does the same thing now with files people send me to check out/edit/help them with.  what's up with that?
RajkumarIlanchelian
We apologize for this inconvenience. The files that you are trying to open were saved in the newer version of Fusion 360 that is not yet available in the Mac App Store. We are actively working with Apple to get the approval to get the latest build on to the app store. I will post back here once we have gotten the approval.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
t_lamourine
cool, do we have an est. time frame?
also, is it possible to just direct download to get the latest version?
thanks for the quick response!
RajkumarIlanchelian
I am hoping that by Tuesday Apple will approve for us. In the mean time if this is stopping your work, you can install Fusion from here - http://www.appstreaming.autodesk.com/install/app/73e72ada57b7480280f7a6f4a289729f/ . We refer to this as our .com install. Since this is up to date you should be able to use the designs that have been saved in the newer version. Once we have the Mac App Store updated you could remove the .com version.
Autodesk Fusion
Join Fusion Insider
t_lamourine
Cool, thanks..I can wait till Tuesday and not have to remove/install/remove/install. 😉
RajkumarIlanchelian
The Mac App Store was updated about 6 hours ago. You should be seeing the update now. Thanks for your patience!
Autodesk Fusion
Join Fusion Insider
t_lamourine
yup, it is, ......download
thanks folks!
