mac update 10.15.7 - fusion360 is crashing at launch
abantu
abantu
hello - i have done a major update today on my mac (is now catalina 10.15.7) and fusion360 is crashing at launch everytime 😩 - anyone an idea how to solve that ? tnx !!
RajkumarIlanchelian
abantu
nope it doesn t - find attached my web services and application logs
abantu
ok - i managed to make fusion360 to work - the issue is not solved but at least you can access your files and kind o work on them
launch your mac in 'safe mode' :
1. shut off the mac entirely
2. after 10" put it back on while you keep the shift key down
3. when you see the apple logo appear you can stop pressing the shift key
the mac starts in safe mode - which means that it doesn t use all extensions and it becomes really slow with graphics
but fusion360 is starting up !
my 'old' mac becomes so slow i can view everything but working on it is ssssssssoooooooooo sllllloooooooowwwww
hopefully this news helps
I have same issue. Hoe for a solution soon.
dgvial
Community Visitor
Community Visitor
I have the same problem, if someone got the solution share it please!
RajkumarIlanchelian
Customers have shared possible workarounds in this thread - https://forums.autodesk.com/t5/fusion-360-support/fusion-360-crashes-on-start-urgent/m-p/10743852/hi...
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
