mac trackpad not working anymore
prettygoodnotbad
Message 1 of 15
prettygoodnotbad
Using macbook pro m1 2020, trackpad, native trackpad enabled.
Since a couple of weeks ago my track pad stopped orbiting and panning properly. If I pan or orbit it'll only make tiny (and very "laggy") micro movements rather than correctly respond to my gestures.
I'll usually end up dragging around the little orbit icon on the top right out of necessity, but then for some reason the movement on the track pad will end up stuck on free orbit without anyway of untethering. I then have to restart fusion.
This is different than the problem before "native trackpad" feature was released because it doesn't only happen after the screen goes to sleep. The trackpad is essentially continually not working properly.
Replies (14)
Message 2 of 15
bentwookie
I haven't been following the bug too closely lately (I've kinda given up on using my Mac for the moment) but there's been some chatter in the forum about a bug which breaks the trackpad when you go in and out of a drawing.
I believe this is one of the threads about it: https://forums.autodesk.com/t5/fusion-360-support/mac-trackpad-zoom-pan-bug/td-p/6657339
Message 3 of 15
prettygoodnotbad
Right ok I will follow this thread, it seems like the conversation has morphed to what my current problem is. The thread looks like a pit of despair but hopefully something comes out of it.. 8 years of people complaining though, I won't hold my breath!
Message 4 of 15
1Macaddict
I'll follow the other thread but thought I'd give an update here also.
It does appear to be when you open a drawing (I created a new drawing to test it vs opening an existing drawing) and the track pad stops working as expected. All I can do is a two finger zoom, no rotation.
I tried to turn off the preview feature for the Mac Trackpad and turn it back on and still the same problem unless I restart Fusion 360.
Fusion 360 2.0.14337
MacBook Pro 2021
Apple M1 Max
64 GB Mem
MacBook Pro 16" 2019 2.4GHz 8-Core i9 64GB
MacBook Pro 16" 2021 M1 Max 64GB
Message 5 of 15
prettygoodnotbad
you are right, I didn't realise that was what was going since I almost always have a drawing open. I also tested it and saw the same issue
Message 6 of 15
nkburdick
I have the same issue as well.  Trackpad Gestures break after opening a drawing.  They are mostly back after restarting Fusion, but the pan and zoom are very slow.  There used to be the typical Mac Interial pan, which is nice and consistent with my other apps, but that is gone.
Message 7 of 15
1Macaddict
I just updated Fusion this morning and all is well for me. I believe the update resolved the issue. Give that a try.
Message 8 of 15
nkburdick
Ok, I just updated.  It doesn't break with the drawing, but I don't have inertia on the panning... do you?
Message 9 of 15
1Macaddict
I'm sorry, I'm not clear what you are asking. For me, everything seems to work as it did before. Can you help me understand what you are not seeing? Thx much
Message 10 of 15
nkburdick
Sure thing.  I have my mac set to inertial scrolling.  When you scroll or pan on pretty much any native Mac App or app that was designed to work with Mac, the pan or scroll comes to a gradual stop instead of just instantly stopping when your finger comes off.  With Fusion 360 now, it's very slow to pan around using my two-finger pan.  It's like I have to push the panning extra far to get a response from the model.  It's referenced in the following forum post:
https://forums.autodesk.com/t5/fusion-360-design-validate/panning-with-trackpad-is-slow/td-p/6940279
To replicate the behavior, trying panning around a model with the two finger pan, then try clicking the pan hand and drag around... the speed is dramatically different.
Does that make sense?  I have attached a screencast as well to help explain.
Message 11 of 15
1Macaddict
Well that's interesting 🙂 Thank you for the explanation and screencast. I didn't realize that the option was in the accessibility settings. I checked and mine is turned on. Scrolling on a browser window does what you describe, slowly decelerates when I scroll up or down as it should.
In Fusion it also works like that in areas like the Data Panel when I'm scrolling up and down.
I don't believe I have ever seen that behavior when I pan, zoom or orbit. I don't see anything different from what I was seeing before after updating this morning.
If there is something else you would like me to try, just let me know.
Message 12 of 15
nkburdick
Thanks for confirming.  I swear it moved faster before in the model space, but maybe I'm mistaken.  I'll monitor the other thread as well and see if Autodesk has plans to update.  It would be nice to move around the model a bit faster.
Message 13 of 15
Hamid_M
While the bug where opening a drawing my have been fixed according nkburdik and 1Macaddict, the original post was about sleep breaking the trackpad behavior, that seems to still be an issue...
Message 14 of 15
1Macaddict
Give this a try hamidJKETL,
I am running Ventura 13.0 so this will look a little different on previous versions of the OS. The System Settings looks have changed dramatically in 13.0
Go to your System Settings, select Battery, select Options, next to Wake for Network Access select either Always or Only on Power Adapter. I have mine set to Only on Power Adapter but Always should work also.
If you need help finding it, let me know.
Message 15 of 15
Hamid_M
Wow @1Macaddict that seems to have worked! Thank you!
