Mac says Fusion 360 is already installed, but is not on my computer anywhere
MKK47
Message 1 of 22
MKK47
I tried to download Fusion 360 and the download manager kept crashing.  I deleted the files, then tried to download again.  Now, the download manager says "Latest version already installed.  You already have the latest version of Fusion 360 installed on this system.  Would you like to start Fusion 360?".  Whether I click Yes or No, nothing happens.   I saw a support post saying to repair the Service Utility, but that is no where on my computer.  I cannot find any files or applications related to Fusion 360 on my computer.   I am using a 2020 MacBook Pro, running Ventura 13.3.1
Replies (21)
Message 2 of 22
RajkumarIlanchelian
@MKK47 If you go to launchpad, do you see Fusion in there? If you do does launching from there work?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 3 of 22
MKK47
No, Fusion is not in the launchpad
Message 4 of 22
MKK47
No, Fusion is not in launchpad.
Message 5 of 22
RajkumarIlanchelian
@MKK47
Go to Finder - Go - Go to folder - /Users/YOUR USER ID/Library/Application Support
Do you see an Autodesk folder in there and if so do you see the Fusion 360 folder in it?
Autodesk Fusion
Join Fusion Insider
Message 6 of 22
MKK47
Yes, I see an Autodesk folder that contains a Fusion 360 folder.  These are the contents of the Fusion 360 folder.
Message 7 of 22
RajkumarIlanchelian
@MKK47 So Fusion is certainly installed. Lets do this:
1. Go to Finder - Go - Go to folder - ~/Applications/
2. This will take you to where the Fusion 360 launcher is
3. Do you see the Fusion 360 launcher and also Fusion 360 service utility?
If you can launch the service utility and then run "Repair Fusion 360" this should get everything in place.
Autodesk Fusion
Join Fusion Insider
Message 8 of 22
MKK47
I do not see the Fusion 360 launcher or service utility
Message 9 of 22
RajkumarIlanchelian
Is that location even available and if so just blank?
Autodesk Fusion
Join Fusion Insider
Message 10 of 22
MKK47
Yes, the location is available, but is completely blank.
Message 11 of 22
RajkumarIlanchelian
@MKK47 OK. It looks like an incomplete install happened. Can you please remove the entire Autodesk folder and then restart your machine, now try an install? This should take care of it.
Autodesk Fusion
Join Fusion Insider
Message 12 of 22
laurens_v_bussel
Observer
Observer
I have the same problem when installing Fusion on mac, but I can't find anything in related to Autodesk/Fusion in the applications folder.
How can I proceed?
Message 13 of 22
RajkumarIlanchelian
@laurens_v_bussel If you go into Launchpad do you see Fusion in there? If you do, then do the following:
1. If Fusion is running close it
2. Delete the shortcut if you have to Fusion
3. Go to Launchpad - Launch Fusion service utility
4. Run the Repair Fusion
This should set everything right for you.
Autodesk Fusion
Join Fusion Insider
Message 14 of 22
laurens_v_bussel
Observer
Observer
no I don't see it on launchpad and it's not in the programs folder either
Message 15 of 22
RajkumarIlanchelian
@laurens_v_bussel
1. If you go into your application folder do you see Fusion there?
2. When you run the installer do you see a message that Fusion is already installed? If you say run it what version of Fusion launches?
3. When it launches can you of into activity monitor and fins Fusion360.exe and find out where this is located?
Autodesk Fusion
Join Fusion Insider
Message 16 of 22
laurens_v_bussel
Observer
Observer
1. no, not in the applications folder
2. Yes, I see the message. But when I click open nothing happens, the installer just shuts
3. Since it doesn't run I can't find the .exe in activity monitor.
Message 17 of 22
RajkumarIlanchelian
@laurens_v_bussel OK. Lets try this:
1 Go to /Users/user/Library/Application Support (Finder - Go - go to folder - /Users/your user name/Library/Application Support/)
2 Delete the Autodesk folder
3. Delete the shortcut that you use to launch Fusion
4. Restart your machine
5. Now install Fusion again.
Autodesk Fusion
Join Fusion Insider
Message 18 of 22
lpobjoyXCZE
Community Visitor
Community Visitor
hey this dosent make any sense and i have the same problem but i can understand the instructions
Message 19 of 22
laurens_v_bussel
Observer
Observer
I found the solution, the autodesk folder was hidden. When I deleted it, I could run a new installation
Message 20 of 22
ruiza1
Community Visitor
Community Visitor
I have tried these steps and do not see the Autodesk or fusion file anywhere.. I even found how to reveal hidden folders within the system and do not see the files.. However, when I try to download I am still getting the dreaded message that its already installed
Please help.. have been on chat several times trying to get this fixed
