Mac OS Big Sur and external GPU (eGPU) issues
jason5YR9X
jason5YR9X
I recently updated to Mac OS Big Sur (11.3). Running on MacBook Pro (13-inch, 2018, 2.3 GHz Quad-Core Intel Core i5).
Fusion works as normal until I connect an external GPU (AMD Radeon RX5700XT inside Razor CoreX).
Screenshot 2021-05-06 at 11.46.22.pngWhen I check the "Prefer external GPU" box on the Fusion360 app and launch it. I get a blank window with just some elements appearing (see screenshot).
This was an issue when I last upgraded to Big Sur 11.1 so I reverted back to the previous OS. Now on 11.3 and it's still an issue.
Is this something Autodesk has on their radar? Can we expect a fix soon?
mohammed.aliTDPXK
Hello @jason5YR9X ,
This seems a known issue, can you please try the below workaround and see if this works?
  1. Close Fusion.
  2. Open Terminal, type launchctl setenv QT_QUICK_BACKEND "software" and press enter.
  3. Close Terminal.
  4. Open Fusion.
If you would like to undo, type launchctl unsetenv QT_QUICK_BACKENDBut this looks like a generic opengl issue. Even if Fusion UI can show, I am not sure the graphics canvas can show properly.
Let me know if this helps.
Mohammed Adam Ali
Sr. SW Eng. Test
Quality Assurance
Autodesk, Inc.
jason5YR9X
Hi @mohammed.aliTDPXK
Thanks for the support. I followed your instructions and now the UI shows, however as you said, the canvas is blank.
When you say this is a generic OpenGL issue does that mean we have to wait for Apple to debug?
Thanks again.
mohammed.aliTDPXK
Hello @jason5YR9X ,
This issue has to be looked by our team and I am not sure when you can see a fix for this item.
Will update you once I get something from the team.
Thanks!
Mohammed Adam Ali
Sr. SW Eng. Test
Quality Assurance
Autodesk, Inc.
